주요 콘텐츠로 건너뛰기
Canon EOS 300 Side Panel with Grip Replacement
필요한 것
  1. Canon EOS 300 Side Panel with Grip Replacement, Batteries: 1 단계, 이미지 3개 중 1개 Canon EOS 300 Side Panel with Grip Replacement, Batteries: 1 단계, 이미지 3개 중 2개 Canon EOS 300 Side Panel with Grip Replacement, Batteries: 1 단계, 이미지 3개 중 3개
    • Open up the battery door.
  2. Canon EOS 300 Side Panel with Grip Replacement: 2 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: 3 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: 3 단계, 이미지 2개 중 2개
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Side Panel with Grip Replacement: 4 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Side Panel with Grip Replacement: 5 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 5 단계, 이미지 2개 중 2개
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Side Panel with Grip Replacement, Front Panel: 6 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement, Front Panel: 6 단계, 이미지 2개 중 2개
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Side Panel with Grip Replacement: 7 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 7 단계, 이미지 2개 중 2개
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Side Panel with Grip Replacement: 8 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: 9 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: 9 단계, 이미지 2개 중 2개
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Side Panel with Grip Replacement: 10 단계, 이미지 3개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 10 단계, 이미지 3개 중 2개 Canon EOS 300 Side Panel with Grip Replacement: 10 단계, 이미지 3개 중 3개
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: 11 단계, 이미지 3개 중 1개 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: 11 단계, 이미지 3개 중 2개 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: 11 단계, 이미지 3개 중 3개
    • Remove the remote control socket cover.
  12. Canon EOS 300 Side Panel with Grip Replacement: 12 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 12 단계, 이미지 2개 중 2개
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Side Panel with Grip Replacement: 13 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 13 단계, 이미지 2개 중 2개
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Side Panel with Grip Replacement: 14 단계, 이미지 2개 중 1개 Canon EOS 300 Side Panel with Grip Replacement: 14 단계, 이미지 2개 중 2개
    • Pry open the side grip using a spudger.
결론
작성자
3다른 기여자 명과 함께
Jordan Tang
회원 가입일: 01/24/14
605 평판
안내서 5개를 작성함
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 회원
CPSU-MANESS-W14S6G20
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 20
전체 시간: 1,238
