주요 콘텐츠로 건너뛰기
Canon EOS 300 Top Panel Replacement
필요한 것
  1. Canon EOS 300 Top Panel Replacement, Batteries: 1 단계, 이미지 1/3 Canon EOS 300 Top Panel Replacement, Batteries: 1 단계, 이미지 2/3 Canon EOS 300 Top Panel Replacement, Batteries: 1 단계, 이미지 3/3
    • Open up the battery door.
  2. Canon EOS 300 Top Panel Replacement: 2 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 2 단계, 이미지 2/2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Top Panel Replacement, Side Panel with Lever: 3 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement, Side Panel with Lever: 3 단계, 이미지 2/2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Top Panel Replacement: 4 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 4 단계, 이미지 2/2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Top Panel Replacement: 5 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 5 단계, 이미지 2/2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Top Panel Replacement, Front Panel: 6 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement, Front Panel: 6 단계, 이미지 2/2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Top Panel Replacement: 7 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 7 단계, 이미지 2/2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Top Panel Replacement: 8 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 8 단계, 이미지 2/2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Top Panel Replacement, Bottom Panel: 9 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement, Bottom Panel: 9 단계, 이미지 2/2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Top Panel Replacement: 10 단계, 이미지 1/3 Canon EOS 300 Top Panel Replacement: 10 단계, 이미지 2/3 Canon EOS 300 Top Panel Replacement: 10 단계, 이미지 3/3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Top Panel Replacement, Side Panel with Grip: 11 단계, 이미지 1/3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: 11 단계, 이미지 2/3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: 11 단계, 이미지 3/3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Top Panel Replacement: 12 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 12 단계, 이미지 2/2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Top Panel Replacement: 13 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 13 단계, 이미지 2/2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Top Panel Replacement: 14 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 14 단계, 이미지 2/2
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Top Panel Replacement, Eyecup: 15 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement, Eyecup: 15 단계, 이미지 2/2
    • With your hands, remove the rubber grip from the eye piece.
  16. Canon EOS 300 Top Panel Replacement: 16 단계, 이미지 1/1
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  17. Canon EOS 300 Top Panel Replacement, Top Panel: 17 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement, Top Panel: 17 단계, 이미지 2/2
    • Remove two silver 5.0mm Phillips #1 screws.
  18. Canon EOS 300 Top Panel Replacement: 18 단계, 이미지 1/1
    • Remove the silver 5.5mm Phillips #1 screw.
  19. Canon EOS 300 Top Panel Replacement: 19 단계, 이미지 1/2 Canon EOS 300 Top Panel Replacement: 19 단계, 이미지 2/2
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tammy Kong
회원 가입일: 01/23/14
771 평판
안내서 6개 작성하였습니다
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 회원
CPSU-MANESS-W14S6G20
4 회원들
안내서 32개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 783
