이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the batteries from the camera by sliding them out into your palm.
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Flip camera over to the bottom.
Remove the one 5mm Phillips #1 silver screw.
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
Remove five black 4.8mm Phillips #1 screws.
Simply remove the bottom panel by prying it off with your finger.
Be wary of a loose piece of foam attached to the bottom panel.
다른 2명이 해당 안내서를 완성하였습니다.
