주요 콘텐츠로 건너뛰기
Canon EOS 40D Battery Door Replacement
필요한 것
  1. Canon EOS 40D Battery Door Replacement, Battery Door: 1 단계, 이미지 1/1
    • After removing the battery, place your index finger between the inner section of the battery door and the battery compartment as shown in the photo.
    • Then place your thumb slightly above the battery door hinge.
  2. Canon EOS 40D Battery Door Replacement: 2 단계, 이미지 1/2 Canon EOS 40D Battery Door Replacement: 2 단계, 이미지 2/2
    • With your thumb, gently press down on the battery door and rotate the battery door clockwise. The upper hinge will pop out and then the lower hinge will pop out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Doug Kruse
회원 가입일: 09/03/15
745 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G3
4 회원들
안내서 16개 작성하였습니다
댓글 105개
fhdfhdfhdfhdgfhfghfghffgjgfjfgfhdffhdfhdfhdfhdgfhfghfghffgjgfjfgfhdf
cyberov50 - 답글
cyberov50 - 답글
cyberov50 - 답글
2000000000000000
cyberov50 - 답글
2000000000000001
cyberov50 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 39
전체 시간: 2,138
