소개
If your date and time battery needs to be replaced, follow this guide to replace it. The required date and time battery is a CR2016 lithium.
필요한 것
Locate the battery compartment cover on the bottom of the camera below the shutter button.
Remove the date and time battery holder by sliding it out of the slot.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 5개
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Great help! Accurate, easy to follow directions
