주요 콘텐츠로 건너뛰기
Canon EOS 40D Shutter Assembly Replacement
필요한 것
  1. Canon EOS 40D Shutter Assembly Replacement, Shutter Assembly: 1 단계, 이미지 1/1
    • Get the Canon 40D Service Repair Manual
    • Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
    • Watch a couple Youtube videos on this process
  2. Canon EOS 40D Shutter Assembly Replacement: 2 단계, 이미지 1/2 Canon EOS 40D Shutter Assembly Replacement: 2 단계, 이미지 2/2
    • Peel off rubber grips
  3. Canon EOS 40D Shutter Assembly Replacement: 3 단계, 이미지 1/1
    • take off front piece
  4. Canon EOS 40D Shutter Assembly Replacement: 4 단계, 이미지 1/2 Canon EOS 40D Shutter Assembly Replacement: 4 단계, 이미지 2/2
    • take off rear
    • connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
  5. Canon EOS 40D Shutter Assembly Replacement: 5 단계, 이미지 1/3 Canon EOS 40D Shutter Assembly Replacement: 5 단계, 이미지 2/3 Canon EOS 40D Shutter Assembly Replacement: 5 단계, 이미지 3/3
    • Take off top cover
  6. Canon EOS 40D Shutter Assembly Replacement: 6 단계, 이미지 1/3 Canon EOS 40D Shutter Assembly Replacement: 6 단계, 이미지 2/3 Canon EOS 40D Shutter Assembly Replacement: 6 단계, 이미지 3/3
    • take off bottom plate
    • disconnect and remove bottom board
  7. Canon EOS 40D Shutter Assembly Replacement: 7 단계, 이미지 1/1
    • remove CMOS assembly
  8. Canon EOS 40D Shutter Assembly Replacement: 8 단계, 이미지 1/1
    • remove metal back
    • remove and replace shutter assembly, transfering components that aren't on the new one
결론
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
wareibevictoriap - 답글
how to replace the focus lock beeper
Dave Reitner - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 29
전체 시간: 7,280
