소개
This is fairly straight forward, and something you may do in the normal use of your camera. It is even in the manual.
  1. Removing the eyepiece is easy.  There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off. Grip the eyepiece by the sides firmly (index finger and thumb).  Wiggle it upwards until it is off.
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Open the battery door Rotate the door so the one side of the hinge pops out (see photo #2)
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
결론
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
다른 4명이 해당 안내서를 완성하였습니다.
Eric D
회원 가입일: 2012년 11월 13일
1,080 평판
안내서 5개 작성하였습니다
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - 답글
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 31
전체 시간: 4,899
