주요 콘텐츠로 건너뛰기
Canon EOS 60D Left-Side Port Cover Replacement
필요한 것
  1. Canon EOS 60D Left-Side Port Cover Replacement, Rubber grips: 1 단계, 이미지 1개 중 1개
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  2. Canon EOS 60D Left-Side Port Cover Replacement, Left-Side Port Cover: 2 단계, 이미지 1개 중 1개
    • Remove 3 screws
    • Remove the small Screw under the Flip cover too
  3. Canon EOS 60D Left-Side Port Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  4. Canon EOS 60D Left-Side Port Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the rear part of the cover out.
  5. Canon EOS 60D Left-Side Port Cover Replacement: 6 단계, 이미지 2개 중 1개 Canon EOS 60D Left-Side Port Cover Replacement: 6 단계, 이미지 2개 중 2개
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eric D
회원 가입일: 11/13/12
1,377 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 41
전체 시간: 7,691
