주요 콘텐츠로 건너뛰기
Canon EOS 60D Motherboard Replacement
필요한 것
  1. Canon EOS 60D Motherboard Replacement, Rear LCD Screen Dissasembly: 1 단계, 이미지 1개 중 1개
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Motherboard Replacement, Removing Rear Cover: 5 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement, Removing Rear Cover: 5 단계, 이미지 2개 중 2개
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
  13. Canon EOS 60D Motherboard Replacement, LCD Screen Swivel Assembly: 13 단계, 이미지 1개 중 1개
    • Carefully pry off the LCD screen connector up from the motherboard to disconnect it, using the plastic opening tool.
  14. Canon EOS 60D Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Remove one 2.8 mm Phillips #PH00 black screw on the side of the swivel assembly by using the PH00 screwdriver.
  15. Canon EOS 60D Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the two 2.8 mm Phillips #PH00 black screws on the back of the swivel assembly using the PH00 screwdriver.
  16. Canon EOS 60D Motherboard Replacement, Motherboard: 16 단계, 이미지 1개 중 1개
    • Remove the two 4.4 mm Phillips #PH00 screws holding the silver cover using the PH00 screwdriver.
    • Next lift the cover off of the motherboard.
  17. Canon EOS 60D Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the small hinge holding the circled gold ribbon in place, then gently slide the ribbon out of the socket.
    • Use cation, and pull the ribbon straight out. If damaged the camera may not work the same after reassembly.
    • Next unscrew the three 4.3 mm Phillips #PH00 screws holding the motherboard down using the PH00 screwdriver.
  18. Canon EOS 60D Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Next the wires are able to come off.
    • The RED arrows indicate a small hinge locking the wire in. To remove the wire, follow the same steps taken to remove the wire in the prior steps.
    • The ORANGE markers indicate that you need to lift the wire up and off of the motherboard. Using the opening tool, follow the same steps used to remove the swivel screen wire.
    • Next it is recommended that you use tweezers to carefully remove all hinged wires as demonstrated by the YELLOW arrow on the second image in this step.
    • It is crucial that you move slowly and carefully! If one of the wires gets damaged, the camera might not work properly after reassembly.
    • You must carefully remove these wires by pulling them straight out of the socket they're seated in.
  19. Canon EOS 60D Motherboard Replacement: 19 단계, 이미지 2개 중 1개 Canon EOS 60D Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • With the motherboard lifted, remove the indicated wire by using a plastic opening tool.
    • With the first bottom wire removed, the motherboard can be lifted higher, showing two more hidden wires.
    • Remove the wire indicated by the ORANGE arrow by undoing a hinge and sliding the wire out.
    • Remove the wire indicated by the YELLOW arrow by gently pulling it straight out of the socket it is seated in.
  20. Canon EOS 60D Motherboard Replacement: 20 단계, 이미지 1개 중 1개
    • With every wire properly removed, the motherboard can now be lifted out of the camera.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Tyler Vaal
회원 가입일: 08/30/15
731 평판
안내서 3개를 작성함
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G6
3 회원들
안내서 14개를 작성함
3가이드 댓글
How do I go about programming a brand new motherboard? Can I do it from my computer?
Awais - 답글
I wanted to ask you a tip. When does the eos 600D no longer turn on where to act? I think the contacts do not touch the battery anymore. Then I have to disassemble the machine to check smd smegs "0". For the moment thank you. I hope to get my Canon back on. Greetings.
Pierpa_76 - 답글
Dear Tyler, there is no need to remove the lcd, the camera can be easily repared by removing the back cover and than loosening the conectors and replacing the motherboard,there is no use in removing the lcd.
Daan geurts - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 69
전체 시간: 10,680
