주요 콘텐츠로 건너뛰기
Canon EOS 60D Rear LCD Screen Replacement
필요한 것
  1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen Dissasembly: 1 단계, 이미지 1개 중 1개
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Canon EOS 60D Rear LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: 5 단계, 이미지 2개 중 1개 Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: 5 단계, 이미지 2개 중 2개
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alejandro Cabrera
회원 가입일: 08/25/15
461 평판
안내서 2개를 작성함
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G6
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 54
전체 시간: 8,682
