주요 콘텐츠로 건너뛰기
Canon EOS 60D Rubber grips Replacement
필요한 것
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: 1 단계, 이미지 1/1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
결론
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
다른 10명이 해당 안내서를 완성하였습니다.
Eric D
회원 가입일: 11/13/12
1,284 평판
안내서 5개 작성하였습니다
댓글 한 개
Where can we get replacement grips?
Luke Lin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 23
전체 시간: 11,905
