주요 콘텐츠로 건너뛰기
Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement
필요한 것
  1. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: 1 단계, 이미지 1/3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: 1 단계, 이미지 2/3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: 1 단계, 이미지 3/3
    • Hold the camera in a top view position allowing for a clear display of the broken top cover.
    • Observe and identify all the pieces of the shattered cover.
  2. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: 2 단계, 이미지 1/3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: 2 단계, 이미지 2/3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: 2 단계, 이미지 3/3
    • Slowly slide the tip of the tweezers under a piece of the broken cover and lift up to remove the broken piece.
    • Use the tweezers to remove another piece of the broken cover.
    • Repeat until all the pieces of the shattered cover are removed.
    • If you begin by removing a piece that is located at an edge of the broken cover, it would facilitate the removal of the rest of the pieces.
    • Use the tweezers carefully while removing the plastic pieces in order to avoid damaging the LCD screen beneath.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Nazmi Bargouthi
회원 가입일: 08/26/15
591 평판
안내서 2개 작성하였습니다
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G6
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 22
전체 시간: 3,349
