주요 콘텐츠로 건너뛰기
Canon EOS 60D USB Replacement connector
필요한 것
  1. Canon EOS 60D USB Replacement connector, Exchange of the connecter card: 1 단계, 이미지 1개 중 1개
    • Also look at the pdf file or I have some photos that could not be deposited in this tutorial
    • Photograph of the broken plug, the central part is no longer centred and moves, hence the loss of USB connection with the computer
  2. Canon EOS 60D USB Replacement connector, View of the defect: 2 단계, 이미지 3개 중 1개 Canon EOS 60D USB Replacement connector, View of the defect: 2 단계, 이미지 3개 중 2개 Canon EOS 60D USB Replacement connector, View of the defect: 2 단계, 이미지 3개 중 3개
    • Seen from the broken socket, the central part almost no longer holds and goes wrong
    • Photo of the item to be replaced (new card)
  3. Canon EOS 60D USB Replacement connector, Or buy the replacement card: 3 단계, 이미지 1개 중 1개
    • After a long search, I was able to find the famous map on the Aliexpress website
  4. Canon EOS 60D USB Replacement connector, tools required: 4 단계, 이미지 1개 중 1개
    • Screwdrivers #00
    • Phone disassembly kit
  5. Canon EOS 60D USB Replacement connector: 5 단계, 이미지 1개 중 1개
  6. Canon EOS 60D USB Replacement connector, Location of the screws to be removed: 7 단계, 이미지 2개 중 1개 Canon EOS 60D USB Replacement connector, Location of the screws to be removed: 7 단계, 이미지 2개 중 2개
  7. Canon EOS 60D USB Replacement connector, Trick: 8 단계, 이미지 1개 중 1개
    • Small tip, to avoid losing the screws I put a magnet so that the screws are "glued" to the screwdriver
  8. Canon EOS 60D USB Replacement connector, After the operations described in the video: 9 단계, 이미지 3개 중 1개 Canon EOS 60D USB Replacement connector, After the operations described in the video: 9 단계, 이미지 3개 중 2개 Canon EOS 60D USB Replacement connector, After the operations described in the video: 9 단계, 이미지 3개 중 3개
    • Once this video has been dismantled, you must see this
    • We can move on to disassembly the card
  9. Canon EOS 60D USB Replacement connector, Unbuttoning connecters and removal of screws: 10 단계, 이미지 1개 중 1개
    • There are 5 screws left to loosen and 6 connecters to unbutton
    • Start removing the 2 connecters in photo 1 with a tweezer, take on the side of the plug without pulling the wires
  10. Canon EOS 60D USB Replacement connector, Removal of connectors: 11 단계, 이미지 1개 중 1개
    • Remove the two cables from these two connecters, as well as the screw on the right
  11. Canon EOS 60D USB Replacement connector, Removal of the screws: 12 단계, 이미지 1개 중 1개
    • 3 screws to remove, one of which is hidden under the yellow tape
    • Remove the plastic cable holder
  12. Canon EOS 60D USB Replacement connector, Screw removal: 13 단계, 이미지 1개 중 1개
    • Remove the last screw
  13. Canon EOS 60D USB Replacement connector, Ribbon connecter: 14 단계, 이미지 1개 중 1개
    • Detach the tablecloth by pulling underneath with a flat screwdriver or with an unfolded paper clip in the hole provided for this purpose
  14. Canon EOS 60D USB Replacement connector, Clear the card: 15 단계, 이미지 1개 중 1개
    • This is the most delicate part to gently clear the card by moving it without forcing it, until it finds its pivot point
    • Be careful, because at the moment there is still a connecter connected under the card. However, the cable is long enough to take it out without worry
    • At the curvature of the red thread, a small bent visible next to the screw hole is observed. It is probably he who makes it so difficult to remove the card.
    • There is a second one on the upper part of the card next to the screw that was under the yellow tape.
  15. Canon EOS 60D USB Replacement connector, Video connecter removal: 16 단계, 이미지 1개 중 1개
    • The connecter undoes very easily by levering on each side of the golden connecter
    • The wide arrow indicates where to pin the soft tablecloth
  16. Canon EOS 60D USB Replacement connector, Card withdrawn: 17 단계, 이미지 1개 중 1개
    • Exchange the deposited card
  17. Canon EOS 60D USB Replacement connector, Reassembly of the card: 18 단계, 이미지 1개 중 1개
    • Put the golden connecter back on, a slight pressure is enough
  18. Canon EOS 60D USB Replacement connector, Identification of the card centring picot: 19 단계, 이미지 1개 중 1개
    • We see where the plastic pin is located that holds the printed circuit board, next to the screw hole
    • Locate the same principle on the top of the map
  19. Canon EOS 60D USB Replacement connector, Rest from the map: 20 단계, 이미지 1개 중 1개
    • Reinsert the tablecloth into its connecter, without forcing, the hole of the tablecloth must be in the plastic pin to be in place
  20. Canon EOS 60D USB Replacement connector, Installation of the cables: 21 단계, 이미지 1개 중 1개
    • Be careful, the screw on the side comes to the arrowhead, the other hole must remain free for the screw of the plastic case (I was wrong)
    • Proceeding with the opposite of the video, everything went well.
    • Just when you put the rear facade back, the screen no longer folded down completely, don't panic, just unlock the three side screws of the card you just changed. The different plastic parts must join without leaving an apparent day.
    • Review the end of the video or this problem is well explained, it is thanks to it that I solved this little problem
  21. Canon EOS 60D USB Replacement connector: 23 단계, 이미지 1개 중 1개
    • Use 3M spray mount glue to glue the rubber sheath on the case
    • Good luck and good photos
결론
To reassemble your device, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
vallet
회원 가입일: 05/21/20
337 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 26
전체 시간: 1,130
