주요 콘텐츠로 건너뛰기
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: 1 단계, 이미지 1/2 Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: 1 단계, 이미지 2/2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: 2 단계, 이미지 1/2 Canon EOS 60D: Replacing Eye piece and Battery door: 2 단계, 이미지 2/2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
결론
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
다른 4명이 해당 안내서를 완성하였습니다.
Eric D
회원 가입일: 11/13/12
1,284 평판
안내서 5개 작성하였습니다
댓글 한 개
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 28
전체 시간: 5,941
