주요 콘텐츠로 건너뛰기
Canon EOS 70D EFS 18-135mm Lens Main Board Replacement
필요한 것
  1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: 1 단계, 이미지 1/3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: 1 단계, 이미지 2/3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: 1 단계, 이미지 3/3
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 2 단계, 이미지 1/2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 2 단계, 이미지 2/2
    • Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
    • Remove the two 4-mm Phillips #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 3 단계, 이미지 1/2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 3 단계, 이미지 2/2
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 4 단계, 이미지 1/2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 4 단계, 이미지 2/2
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 5 단계, 이미지 1/3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 5 단계, 이미지 2/3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 5 단계, 이미지 3/3
    • Remove the two 4-mm Phillips #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paul
회원 가입일: 03/12/18
792 평판
안내서 3개 작성하였습니다
University of Memphis, Team S2-G5, Kim Spring 2018 University of Memphis, Team S2-G5, Kim Spring 2018 회원
UM-KIM-S18S2G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 29
전체 시간: 2,327
