주요 콘텐츠로 건너뛰기
Canon EOS A2 Front Cover Replacement
필요한 것
  1. Canon EOS A2 Front Cover Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  2. Canon EOS A2 Front Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  3. Canon EOS A2 Front Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery from inside the battery housing and set the cover aside.
  4. Canon EOS A2 Front Cover Replacement, Front Cover: 4 단계, 이미지 1개 중 1개
    • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
  5. Canon EOS A2 Front Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 6.4mm screw from the inside of the flash bezel.
    • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
  6. Canon EOS A2 Front Cover Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
  7. Canon EOS A2 Front Cover Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 5.6mm screws behind the battery cover.
  8. Canon EOS A2 Front Cover Replacement: 8 단계, 이미지 1개 중 1개
    • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
  9. Canon EOS A2 Front Cover Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
  10. Canon EOS A2 Front Cover Replacement: 10 단계, 이미지 2개 중 1개 Canon EOS A2 Front Cover Replacement: 10 단계, 이미지 2개 중 2개
    • Starting at the flash, carefully pull the front cover away from the camera.
결론
작성자
5다른 기여자 명과 함께
Mark
회원 가입일: 04/20/11
197 평판
안내서 5개를 작성함
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 회원
CPSU-REGAN-S11S8G9
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 2,841
