주요 콘텐츠로 건너뛰기
Canon EOS Rebel G Back Panel Replacement
필요한 것
  1. Canon EOS Rebel G Back Panel Replacement, Front Panel: 1 단계, 이미지 1/1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Replacement: 2 단계, 이미지 1/2 Canon EOS Rebel G Back Panel Replacement: 2 단계, 이미지 2/2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Replacement: 3 단계, 이미지 1/3 Canon EOS Rebel G Back Panel Replacement: 3 단계, 이미지 2/3 Canon EOS Rebel G Back Panel Replacement: 3 단계, 이미지 3/3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Replacement, Top Panel: 4 단계, 이미지 1/1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Back Panel Replacement: 5 단계, 이미지 1/1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Back Panel Replacement: 6 단계, 이미지 1/1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Back Panel Replacement: 7 단계, 이미지 1/3 Canon EOS Rebel G Back Panel Replacement: 7 단계, 이미지 2/3 Canon EOS Rebel G Back Panel Replacement: 7 단계, 이미지 3/3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Back Panel Replacement, Back Panel: 8 단계, 이미지 1/1
    • Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
    • Remove the strap anchor.
  9. Canon EOS Rebel G Back Panel Replacement: 9 단계, 이미지 1/1
    • Unlatch the back panel.
    • Using a #00 Phillips screw driver, unscrew the six screws on the bottom of the camera.
    • One 7.4 mm Phillips screw
    • Two 6.0 mm Phillips screws
    • Two 4.4 mm Phillips screws
    • One 3.9 mm Phillips screw
  10. Canon EOS Rebel G Back Panel Replacement: 10 단계, 이미지 1/3 Canon EOS Rebel G Back Panel Replacement: 10 단계, 이미지 2/3 Canon EOS Rebel G Back Panel Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • From the bottom of the camera push the hinge rod in with your finger.
    • Return the camera to its upright position.
    • Use pliers (or tweezers) to pull the rod out from the top.
결론
Zach
회원 가입일: 04/04/12
43 평판
안내서 8개 작성하였습니다
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 회원
CPSU-FORTE-S12S14G9
5 회원들
안내서 36개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,907
