주요 콘텐츠로 건너뛰기
Canon EOS Rebel G Grip Replacement
필요한 것
  1. Canon EOS Rebel G Grip Replacement, Front Panel: 1 단계, 이미지 1/1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: 2 단계, 이미지 1/2 Canon EOS Rebel G Grip Replacement: 2 단계, 이미지 2/2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: 3 단계, 이미지 1/3 Canon EOS Rebel G Grip Replacement: 3 단계, 이미지 2/3 Canon EOS Rebel G Grip Replacement: 3 단계, 이미지 3/3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: 4 단계, 이미지 1/1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: 5 단계, 이미지 1/1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: 6 단계, 이미지 1/2 Canon EOS Rebel G Grip Replacement: 6 단계, 이미지 2/2
    • Use the flat end of a spudger to pop the grip off and remove grip.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Reis
회원 가입일: 04/02/12
52 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 회원
CPSU-FORTE-S12S14G9
5 회원들
안내서 36개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 1,583
