주요 콘텐츠로 건너뛰기
Canon EOS Rebel G Viewfinder Replacement
필요한 것
  1. Canon EOS Rebel G Viewfinder Replacement, Front Panel: 1 단계, 이미지 1/1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Viewfinder Replacement: 2 단계, 이미지 1/2 Canon EOS Rebel G Viewfinder Replacement: 2 단계, 이미지 2/2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Viewfinder Replacement: 3 단계, 이미지 1/3 Canon EOS Rebel G Viewfinder Replacement: 3 단계, 이미지 2/3 Canon EOS Rebel G Viewfinder Replacement: 3 단계, 이미지 3/3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Viewfinder Replacement, Top Panel: 4 단계, 이미지 1/1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Viewfinder Replacement: 5 단계, 이미지 1/1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Viewfinder Replacement: 6 단계, 이미지 1/1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Viewfinder Replacement: 7 단계, 이미지 1/3 Canon EOS Rebel G Viewfinder Replacement: 7 단계, 이미지 2/3 Canon EOS Rebel G Viewfinder Replacement: 7 단계, 이미지 3/3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Viewfinder Replacement, Viewfinder: 8 단계, 이미지 1/1
    • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
    • Two 8.5 mm Phillips screws
결론
Kyle Reis
회원 가입일: 04/02/12
52 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 회원
CPSU-FORTE-S12S14G9
5 회원들
안내서 36개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 2,997
