주요 콘텐츠로 건너뛰기
Canon EOS Rebel T1i Camera Battery Notch Replacement
필요한 것
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: 1 단계, 이미지 1/2 Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: 1 단계, 이미지 2/2
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a #00 Phillips screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: 2 단계, 이미지 1/2 Canon EOS Rebel T1i Camera Battery Notch Replacement: 2 단계, 이미지 2/2
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: 3 단계, 이미지 1/3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 3 단계, 이미지 2/3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 3 단계, 이미지 3/3
    • Unscrew the bottom three 4mm screws with a #00 Phillips screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: 4 단계, 이미지 1/1
    • Unscrew the inner 4mm screw with a #00 Phillips screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: 5 단계, 이미지 1/2 Canon EOS Rebel T1i Camera Battery Notch Replacement: 5 단계, 이미지 2/2
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: 6 단계, 이미지 1/3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 6 단계, 이미지 2/3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 6 단계, 이미지 3/3
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: 7 단계, 이미지 1/3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 7 단계, 이미지 2/3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 7 단계, 이미지 3/3
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jonathan Lin
회원 가입일: 04/14/14
548 평판
안내서 4개 작성하였습니다
Cal Poly, Team 3-41, Maness Spring 2014 Cal Poly, Team 3-41, Maness Spring 2014 회원
CPSU-MANESS-S14S3G41
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 29
전체 시간: 3,185
