주요 콘텐츠로 건너뛰기
Canon EOS Rebel T1i Front Screen Replacement
필요한 것
  1. Canon EOS Rebel T1i Front Screen Replacement, Front Screen: 1 단계, 이미지 1/1
    • Clean the broken or cracked screen as best as possible.
    • Place the suction cup on the damaged screen.
  2. Canon EOS Rebel T1i Front Screen Replacement: 2 단계, 이미지 1/2 Canon EOS Rebel T1i Front Screen Replacement: 2 단계, 이미지 2/2
    • While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
  3. Canon EOS Rebel T1i Front Screen Replacement: 3 단계, 이미지 1/3 Canon EOS Rebel T1i Front Screen Replacement: 3 단계, 이미지 2/3 Canon EOS Rebel T1i Front Screen Replacement: 3 단계, 이미지 3/3
    • Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture.
    • Remove the plastic screen from the camera.
    • Release the broken screen by pulling down the lever of the suction cup.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Michael Peck
회원 가입일: 04/14/14
167 평판
안내서 1개 작성함
Cal Poly, Team 3-41, Maness Spring 2014 Cal Poly, Team 3-41, Maness Spring 2014 회원
CPSU-MANESS-S14S3G41
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Be sure to measure the size of your screen before buying the suction cups. I got the heavy-duty ones and then found that they were too big for my Rebel T1i screen.
cmorris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 26
전체 시간: 5,467
