주요 콘텐츠로 건너뛰기
Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement
필요한 것
  1. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement, Dioptric Adjustment Lens: 1 단계, 이미지 1/2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement, Dioptric Adjustment Lens: 1 단계, 이미지 2/2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 2 단계, 이미지 1/1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 3 단계, 이미지 1/1
    • On the top cover, remove the two screws from under the metal tabs that are used to attach the camera straps.
  4. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 4 단계, 이미지 1/1
    • Remove the two screws on the right side of the camera.
  5. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 5 단계, 이미지 1/1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two black screws.
  6. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 6 단계, 이미지 1/1
    • Remove the two screws beneath the eyepiece
  7. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 7 단계, 이미지 1/1
    • Remove the screw in the center of the viewfinder focus knob located to the right of the eyepiece.
  8. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 8 단계, 이미지 1/1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  9. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 9 단계, 이미지 1/3 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 9 단계, 이미지 2/3 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 9 단계, 이미지 3/3
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
    • Remove the ribbon connector on the lower left hand side of the circuit board.
  10. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 10 단계, 이미지 1/1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  11. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 11 단계, 이미지 1/1
    • Remove the ribbon connector on the upper right hand side of the circuit board.
    • Remove the microphone connection on the upper left hand side of the circuit board.
  12. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 12 단계, 이미지 1/1
    • On the lower left side on the front of the camera, disconnect the red and yellow wires from the circuit board.
  13. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 13 단계, 이미지 1/1
    • Pull the top cover free.
  14. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 14 단계, 이미지 1/2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 14 단계, 이미지 2/2
    • Remove the red wire that travels across the mirror box.
  15. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 15 단계, 이미지 1/1
    • Remove the 4 screws holding the mirror box in place.
  16. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 16 단계, 이미지 1/2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 16 단계, 이미지 2/2
    • Remove 3 screws to disconnect the ribbon mount assembly
  17. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 17 단계, 이미지 1/2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 17 단계, 이미지 2/2
    • Now that the top assembly is free, this exposes another screw on the right side of the mirror box.
    • Remove this screw.
    • Remove the orange ribbon cable.
  18. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 18 단계, 이미지 1/1
    • Remove the viewfinder assembly from the camera.The screws that hold the eyepiece in place are accessible. Remove these 3 screws from the rear face of the eyepiece. Two screws are located at the bottom and one screw is located on top.
  19. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 19 단계, 이미지 1/2 Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 19 단계, 이미지 2/2
    • With the screws removed, the eyepiece can easily be pulled free.
  20. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 20 단계, 이미지 1/1
    • Swivel the dioptric lens 90 degrees.
  21. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 21 단계, 이미지 1/1
    • Remove pin with tweezers.
  22. Canon EOS Rebel T2i Dioptric Adjustment Lens Replacement: 22 단계, 이미지 1/1
    • Compress spring and remove spring and dioptric lens assembly
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Jaskolka
회원 가입일: 03/30/15
745 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Thank u for the clear directives.
Really helped
For those who are intending to clean the internal prism mirrors, do note the two pieces on the top are no made of glass hence easily scratched. Best to avold wiping them.
Lex - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 32
전체 시간: 3,548
