주요 콘텐츠로 건너뛰기
Canon EOS Rebel T2i Hot Shoe Replacement
필요한 것
  1. Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: 1 단계, 이미지 1/3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: 1 단계, 이미지 2/3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: 1 단계, 이미지 3/3
    • Using the flat end of the spudger, carefully pry the rear part of the hot shoe baseplate upward.
    • Pull the spudger backwards to remove the base plate.
    • Removing this plate reveals the mounting screws for the hot shoe.
  2. Canon EOS Rebel T2i Hot Shoe Replacement: 2 단계, 이미지 1/1
    • To remove the hot shoe, unscrew the 4 mounting screws holding it in place.
  3. Canon EOS Rebel T2i Hot Shoe Replacement: 3 단계, 이미지 1/1
    • With the screws removed, the hot shoe can now be lifted out of place.
결론
To reassemble your device, follow these instructions in reverse order. When tightening screws that hold the hot shoe in place, be very careful to not scratch the rail of the hot shoe. If the rail of the hot shoe has any scratches or dents, it can be more difficult to mount the external flash.
다른 2명이 해당 안내서를 완성하였습니다.
Jacob Jaskolka
회원 가입일: 03/30/15
745 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
My hot shoe actually came off. I have ordered various sizes of screws to replace it but none work. I need a new hot shoe and screws. What size screws do I need with a canon rebel T2i camera?
Cindy Mitchum - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 30
전체 시간: 5,632
