주요 콘텐츠로 건너뛰기
Canon EOS Rebel T2i Top Casing Replacement
필요한 것
  1. Canon EOS Rebel T2i Top Casing Replacement, Remove the battery.: 1 단계, 이미지 1/2 Canon EOS Rebel T2i Top Casing Replacement, Remove the battery.: 1 단계, 이미지 2/2
    • Remove the battery using the 00 screwdriver.
    • Remove the neck strap
    • Remove the plastic casing around the viewing lens
  2. Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: 2 단계, 이미지 1/3 Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: 2 단계, 이미지 2/3 Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: 2 단계, 이미지 3/3
    • Remove these screws.
  3. Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: 3 단계, 이미지 1/3 Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: 3 단계, 이미지 2/3 Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: 3 단계, 이미지 3/3
  4. Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: 4 단계, 이미지 1/3 Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: 4 단계, 이미지 2/3 Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: 4 단계, 이미지 3/3
    • Remove the screws below the view finder.
    • Remove the screw of the focus wheel right from the view finder using the 000 screw driver
    • Remove the top screws.
    • Using your fingers, remove the left wire connecting the microphone.
  5. Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: 5 단계, 이미지 1/3 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: 5 단계, 이미지 2/3 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: 5 단계, 이미지 3/3
    • Use your fingers to complete the following steps. Remove the black wire beneath the power switch.
    • Remove the wire on the left side shown.
    • Remove the two ribbon wires on the right side.
  6. Canon EOS Rebel T2i Top Casing Replacement, Remove top casing and replace with a new casing.: 6 단계, 이미지 1/2 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing and replace with a new casing.: 6 단계, 이미지 2/2
    • Remove the circled wires on the front with your fingers.
    • Remove the top casing and replace it with a new one. This casing should include a new power switch. Reconnect all wires and replace the back and front casings.
결론
This guide demonstrates how to replace the power button. To reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Stefan Seitler
회원 가입일: 10/27/14
470 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-4, Duarte Fall 2014 UMass Dartmouth, Team 1-4, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G4
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
The top cover assembly part number for the Rebel T2i/EOS 550D is CG2-2756-010.
ogminlo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 2,762
