주요 콘텐츠로 건너뛰기
Canon EOS Rebel T2i Tripod Mount Replacement
필요한 것
  1. Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: 1 단계, 이미지 1/2 Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: 1 단계, 이미지 2/2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Tripod Mount Replacement: 2 단계, 이미지 1/1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Tripod Mount Replacement: 3 단계, 이미지 1/1
    • Remove the two screws on the right side of the camera.
  4. Canon EOS Rebel T2i Tripod Mount Replacement: 4 단계, 이미지 1/1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two silver screws.
  5. Canon EOS Rebel T2i Tripod Mount Replacement: 5 단계, 이미지 1/1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  6. Canon EOS Rebel T2i Tripod Mount Replacement: 6 단계, 이미지 1/2 Canon EOS Rebel T2i Tripod Mount Replacement: 6 단계, 이미지 2/2
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
  7. Canon EOS Rebel T2i Tripod Mount Replacement: 7 단계, 이미지 1/1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  8. Canon EOS Rebel T2i Tripod Mount Replacement: 8 단계, 이미지 1/2 Canon EOS Rebel T2i Tripod Mount Replacement: 8 단계, 이미지 2/2
    • The screws holding the tripod mount are now exposed.
    • Remove the screws securing the tripod mount
    • With the screws removed, the tripod mount can now be easily pulled free.
결론
Jacob Jaskolka
회원 가입일: 03/30/15
745 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 1,642
