소개
Use this guide to replace the top casing on your Canon EOS Rebel T3i.
필요한 것
Remove the four 5 mm Phillips #000 screws.
The 6mm screw would sit in the bottom right hole, if it has this one longer screw.
Lift off the USB cover.
Make sure the viewfinder eyepiece is removed, otherwise it will hold the top left corner of the back part in place.
Lift the top casing up and away from the camera.
I'm not sure what this is for, but make sure the black plastic bit (not a cable) goes into the white plastic bit, as shown on the picture.
Here is a view of the black plastic bit. It is on the underside of the top cover.
I am speculating but I believe this is a fiber optic cable that has to do with the flash control. Make sure it is seated all the way down into the white plastic tube (not the metal clip in front of it). Also if you are repairing a damaged top there could be a piece of the old cable down in the hole as was the case for me and you will have to remove it before putting the new top on. I have pictures but don't see any way I can attach them here.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 6개
Thanks for this guide, it was helpful. I edited it to add some details, I hope they help the next person.
My camera is also this model, but I found that there were some differences, and I'm wondering it I got a refurbished device for the price of a new one... For instance the top cable were soldered to the front of the camera, no plug in sight. I found more than 1 screw that had a different thread to the others.
All in all I managed to fix my issue which was with the viewfinder. The 550D guide for the viewfinder will work for this camera (I just used it and the viewfinder parts are exactly the same) Canon EOS Rebel T2i Eyepiece Replacement
Good guide, only comment I have is there is a cover over the viewfinder that you need to remove initially, you just pull up on it and it pops off. If you look closely at the viewfinder on the camera in the pictures you will probably see that it does not have a cover around the viewfinder that your camera does. This needs to be removed before removing the back of the camera.
For me some bolt sizes were also different, i just labeled every bolt location with a piece of tape with a number written on it, and kept track of the bolts.
This briliant. I don't dare to unscrew my camera yet but if I do this will certainly help. I did do the back cover already but the top cover is serious business. Thanks a lot for the many photo's provided.
Excelent step-by-step! I managed to fix my camera's flash mechanism without buying any part.
By the way, that small plastic that looks a cable but it's not a cable is an optic fiber, that carries a small amount of the flash light to a sensor on the board.
A lens in the eyepiece of my 600D was popped out. I used this guide and this one: Canon EOS Rebel T2i Eyepiece Replacement to fix it. Thanks!
