주요 콘텐츠로 건너뛰기
Canon EOS Rebel T4i Battery Replacement
  1. Canon EOS Rebel T4i Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Battery Replacement: 2 단계, 이미지 1/1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nimisha Patel
회원 가입일: 04/14/14
164 평판
안내서 1개 작성함
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 회원
CPSU-MANESS-S14S12G33
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 25
전체 시간: 3,052
