소개
This guide details how to replace the flash bulb of this camera.
부품
지정된 부품이 없습니다.
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 3개
how do you reverse step 6 - cutting the wires?
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
