주요 콘텐츠로 건너뛰기
Canon EOS Rebel T4i Flash Replacement
필요한 것
  1. Canon EOS Rebel T4i Flash Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Flash Replacement: 2 단계, 이미지 1/1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Flash Replacement, Flash: 3 단계, 이미지 1/1
    • Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
  4. Canon EOS Rebel T4i Flash Replacement: 4 단계, 이미지 1/1
    • Remove the covering.
  5. Canon EOS Rebel T4i Flash Replacement: 5 단계, 이미지 1/1
    • Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
  6. Canon EOS Rebel T4i Flash Replacement: 6 단계, 이미지 1/1
    • Use the wire cutters to cut the wiring connected to the flash.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Jordan Rabold
회원 가입일: 04/14/14
774 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 회원
CPSU-MANESS-S14S12G33
4 회원들
안내서 14개 작성하였습니다
댓글 3개
how do you reverse step 6 - cutting the wires?
jeremyyoung - 답글
You dont tell how to make sure capacitors are discharged before changing the flash ? and do you know what is the replacement number of the flash bulb itself ?
jackqc09 - 답글
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
gustavoaleme - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 4,368
