주요 콘텐츠로 건너뛰기
Canon EOS Rebel T4i Motherboard Replacement
필요한 것
  1. Canon EOS Rebel T4i Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Motherboard Replacement: 2 단계, 이미지 1/1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Canon EOS Rebel T4i Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Use the spudger to pry off the rubber grip and reveal the screws.
    • Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
  4. Canon EOS Rebel T4i Motherboard Replacement: 4 단계, 이미지 1/3 Canon EOS Rebel T4i Motherboard Replacement: 4 단계, 이미지 2/3 Canon EOS Rebel T4i Motherboard Replacement: 4 단계, 이미지 3/3
    • Pull off the plastic cover from the viewfinder.
    • Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
  5. Canon EOS Rebel T4i Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the following screws from the device using the Phillips #00 screwdriver:
    • Two 3.4mm Phillips head screws.
    • Two 5.9mm Phillips head screw.
  6. Canon EOS Rebel T4i Motherboard Replacement: 6 단계, 이미지 1/1
    • One 3.4mm Phillips head screw.
    • One 5.9 mm Phillips head screw.
  7. Canon EOS Rebel T4i Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the rear panel from the camera.
    • Several fragile cables are attached to the inside of the panel, so remove it gently.
  8. Canon EOS Rebel T4i Motherboard Replacement: 8 단계, 이미지 1/3 Canon EOS Rebel T4i Motherboard Replacement: 8 단계, 이미지 2/3 Canon EOS Rebel T4i Motherboard Replacement: 8 단계, 이미지 3/3
    • In the lower right corner of the mother board, detach the blue cable.
    • Then detach the ribbon cable going from the motherboard to the rear panel.
  9. Canon EOS Rebel T4i Motherboard Replacement: 9 단계, 이미지 1/1
    • In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
  10. Canon EOS Rebel T4i Motherboard Replacement: 10 단계, 이미지 1/3 Canon EOS Rebel T4i Motherboard Replacement: 10 단계, 이미지 2/3 Canon EOS Rebel T4i Motherboard Replacement: 10 단계, 이미지 3/3
    • Use the plastic opening tool to flip up ribbon cable connector.
    • Gently disconnect the ribbon cable by pulling it away from the motherboard.
  11. Canon EOS Rebel T4i Motherboard Replacement: 11 단계, 이미지 1/2 Canon EOS Rebel T4i Motherboard Replacement: 11 단계, 이미지 2/2
    • In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
  12. Canon EOS Rebel T4i Motherboard Replacement: 12 단계, 이미지 1/2 Canon EOS Rebel T4i Motherboard Replacement: 12 단계, 이미지 2/2
    • Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
  13. Canon EOS Rebel T4i Motherboard Replacement: 13 단계, 이미지 1/2 Canon EOS Rebel T4i Motherboard Replacement: 13 단계, 이미지 2/2
    • Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard.
    • Make sure all cables are disconnected from the motherboard.
  14. Canon EOS Rebel T4i Motherboard Replacement: 14 단계, 이미지 1/2 Canon EOS Rebel T4i Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the following screws from the motherboard using the Phillips #00 screwdriver:
    • Two 3.9mm Phillips head screws.
    • Three 2.9mm Phillips head screws
    • Gently pull the motherboard out of the camera.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Jordan Rabold
회원 가입일: 04/14/14
774 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 회원
CPSU-MANESS-S14S12G33
4 회원들
안내서 13개 작성하였습니다
2 댓글
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
Flying Dutchman - 답글
Where can we buy the parts?
tjt263 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 43
전체 시간: 13,505
