주요 콘텐츠로 건너뛰기
Canon EOS Rebel T6i PCB Flashboard Replacement
필요한 것
  1. Canon EOS Rebel T6i PCB Flashboard Replacement, Flash Assembly: 1 단계, 이미지 3개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement, Flash Assembly: 1 단계, 이미지 3개 중 2개 Canon EOS Rebel T6i PCB Flashboard Replacement, Flash Assembly: 1 단계, 이미지 3개 중 3개
    • Remove two 6.8 mm JIS #000 screws on the right side.
    • Remove six 5.3 mm JIS #000 screws on the bottom.
    • Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
  2. Canon EOS Rebel T6i PCB Flashboard Replacement: 2 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove one 5.9 mm JIS #000 screw on the top right.
    • Remove one 3.4 mm JIS #000 screw on the top left.
  3. Canon EOS Rebel T6i PCB Flashboard Replacement: 3 단계, 이미지 3개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 3 단계, 이미지 3개 중 2개 Canon EOS Rebel T6i PCB Flashboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using a metal spudger, pry the rubber grip off of the casing on the left side of the camera.
    • Potential for device damage: Be careful not to rip the rubber with the metal spudger.
    • Remove five silver 5.8 mm JIS #000 screws from underneath the grip.
  4. Canon EOS Rebel T6i PCB Flashboard Replacement: 4 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 4 단계, 이미지 2개 중 2개
    • Using the metal spudger, pry the rubber grip located just below the turndial.
    • Potential for device damage: Be careful not to rip the rubber.
  5. Canon EOS Rebel T6i PCB Flashboard Replacement: 5 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully use the plastic opening tool to pry the casing apart along the seam.
    • Follow the seam with the plastic tool until the back is ready to remove.
    • Potential for device damage: Make sure you use the grounding strip to remove the chance of discharging static electricity into the internal components.
  6. Canon EOS Rebel T6i PCB Flashboard Replacement: 6 단계, 이미지 3개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 6 단계, 이미지 3개 중 2개 Canon EOS Rebel T6i PCB Flashboard Replacement: 6 단계, 이미지 3개 중 3개
    • Notice the two connections attaching the back of the camera to the motherboard.
    • To disconnect the white wire, pinch the wire casing and pull it directly out from the camera.
    • This may take a very small amount of strength; however, do not force or pry it.
    • To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
    • Once removed, set the back in a safe place.
  7. Canon EOS Rebel T6i PCB Flashboard Replacement: 7 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
    • Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
  8. Canon EOS Rebel T6i PCB Flashboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the button cell battery from the motherboard using a pair of tweezers.
  9. Canon EOS Rebel T6i PCB Flashboard Replacement: 9 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
    • Disconnect the three ribbon connectors along the top.
    • Don't detach the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
  10. Canon EOS Rebel T6i PCB Flashboard Replacement: 10 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
    • Remove the four screws from the bottom of the camera.
  11. Canon EOS Rebel T6i PCB Flashboard Replacement: 11 단계, 이미지 3개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 11 단계, 이미지 3개 중 2개 Canon EOS Rebel T6i PCB Flashboard Replacement: 11 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, pry the front of the casing off of the camera.
    • Warning: Electric Shock! Be careful not to touch the terminals of the capacitor (black cylinder). This can cause the capacitor to discharge.
  12. Canon EOS Rebel T6i PCB Flashboard Replacement: 12 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the yellow and red connections on the front near the black cylinder (capacitor).
    • The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
    • The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
  13. Canon EOS Rebel T6i PCB Flashboard Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the diopter adjustment knob next to the viewfinder using a JIS #000 screwdriver.
  14. Canon EOS Rebel T6i PCB Flashboard Replacement: 14 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the entire upper flash assembly by gently pulling it up and off the camera.
    • The flash assembly is sold as a single piece.
  15. Canon EOS Rebel T6i PCB Flashboard Replacement, Motherboard: 15 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement, Motherboard: 15 단계, 이미지 2개 중 2개
    • Disconnect the ribbon connector on the upper right side of the motherboard.
    • Pull back the foam on the connector on the far right side of the motherboard.
    • Flip up the tab on the connector and remove the cable.
  16. Canon EOS Rebel T6i PCB Flashboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the two screws on the right side of the motherboard as well as the screw in the center.
  17. Canon EOS Rebel T6i PCB Flashboard Replacement: 17 단계, 이미지 2개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the two screws connecting the metal port bracket to the motherboard.
    • Slide the metal bracket out of the camera.
  18. Canon EOS Rebel T6i PCB Flashboard Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the motherboard from the device.
  19. Canon EOS Rebel T6i PCB Flashboard Replacement, Capacitor PCB Flash Board: 19 단계, 이미지 1개 중 1개
    • Caution: Failure to follow these steps may lead to damage or injury from electrical shock. Before removing or touching the PCB board, the capacitor needs to be checked for voltage. This device is the black cylinder on the camera.
    • Place a voltmeter in parallel with the capacitor. If a charge is detected, make sure the battery is removed from the device.
    • The positive pin is connected to the positive terminal and negative to the negative terminal. Switch the setting of the multimeter to ADC for direct current amperage.
  20. Canon EOS Rebel T6i PCB Flashboard Replacement: 20 단계, 이미지 1개 중 1개
    • The meter will fluctuate with a current until reaching zero. This process will discharge any residual charge.
    • Caution: Failure to discharge the capacitor may lead to electrical discharge and shock. The meter must reach zero to prevent any further damage to the camera.
  21. Canon EOS Rebel T6i PCB Flashboard Replacement: 21 단계, 이미지 3개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 21 단계, 이미지 3개 중 2개 Canon EOS Rebel T6i PCB Flashboard Replacement: 21 단계, 이미지 3개 중 3개
    • Potential for device damage: Using a magnetic-tipped screw driver may cause damage to the board.
    • Remove three screws from the motherboard.
    • Disconnect six ribbon connectors from the motherboard.
    • Remove the four wire connectors on the front of the motherboard.
    • Remove the two wire connectors on the back of the motherboard.
  22. Canon EOS Rebel T6i PCB Flashboard Replacement: 22 단계, 이미지 3개 중 1개 Canon EOS Rebel T6i PCB Flashboard Replacement: 22 단계, 이미지 3개 중 2개 Canon EOS Rebel T6i PCB Flashboard Replacement: 22 단계, 이미지 3개 중 3개
    • Verify that the power cable has also been removed.
    • Remove the PCB flash board from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Shane Riding
회원 가입일: 03/21/18
864 평판
안내서 4개를 작성함
2가이드 댓글
When reassembling does the leather material go back into place without adding more adhesive?
Dave Cupp - 답글
From my experience they usually do. However if you find it doesn't stick very well afterwards, you can try using some contact cement to hold it in place.
Zephosk -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 40
전체 시간: 2,069
