소개
This guide will show you how to replace the front cover of the camera. This is useful both if you're replacing the front cover, or needing to gain access to other components in the camera such as the top cover.
Note that the Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
필요한 것
Before beginning, remove the battery and SD card from the camera.
Using your thumbs, push up on the eyepiece to remove it.
Remove the battery door.
Open the battery door to about a 35° angle.
Pull the battery door straight outwards.
Underneath the right I/F terminal cap, remove the following screws:
Two M1.7x5.5mm JIS #000 screws
On the right side of the camera, remove the following screws:
Two M1.7x4.5mm JIS #000 screws
On the back of the camera, remove the following screws next to the viewfinder:
Two M1.7x5.0mm Phillips #000 screws
On the bottom of the camera, remove the following screws:
Four M1.7x5.0mm Phillips #000 screws
Using a plastic opening pick, partially peel up the top of the back rubber grip.
Carefully begin lifting the back cover up away from the camera body.
Using a plastic spudger tool, gently pry off the back cover ribbon cable from the main PCB board.
Underneath the left I/F terminal cap, remove the following screw:
Using a plastic opening pick, peel off the front name plate.
Underneath where the name plate was, remove the following screw:
One M1.7x5.5mm Phillips #000 screw
Pull off the I/F terminal cover.
