소개
Removing the I/F terminal cover is useful if you need to replace the cover itself or the two rubber I/F terminal caps. It is also necessary to remove in order to disassemble certain parts of the camera, including any that requires the removal of the front cover.
Note that the Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
필요한 것
Before beginning, remove the battery from the camera.
Underneath the two I/F terminal caps, remove the following screws:
Three M1.7x5.5mm JIS #000 screws
Using a plastic opening pick, peel off the front name plate.
Underneath where the name plate was, remove the following screw:
One M1.7x5.5mm Phillips #000 screw
