주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS 35mm Bottom Cover Replacement
필요한 것
  1. Canon EOS Rebel XS 35mm Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover Replacement: 2 단계, 이미지 1/1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
결론
christiansvezia
회원 가입일: 10/24/18
1,108 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 201
