주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS 35mm Bottom Cover and More Replacement
필요한 것
  1. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 2 단계, 이미지 1/1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover and More: 4 단계, 이미지 1/1
    • Remove the 5mm silver Phillips #000 screw.
    • Remove three 4mm Phillips #000 screws.
  5. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the silver plate with tweezers or fingers.
  6. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 6 단계, 이미지 1/1
    • Be mindful of the spring attached to the plastic piece. Do not lose it.
    • Remove the plastic black part.
  7. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 7 단계, 이미지 1/1
    • Remove the black gear with tweezers or fingers.
  8. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 8 단계, 이미지 1/1
    • Remove the gear with tweezers or fingers.
  9. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 9 단계, 이미지 1/1
    • Remove the part indicated in the picture with tweezers or fingers.
  10. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 10 단계, 이미지 1/1
  11. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 11 단계, 이미지 1/1
  12. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 12 단계, 이미지 1/2 Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 12 단계, 이미지 2/2
    • Remove two 3mm Phillips #000 screws.
    • Remove two silver 3.5mm Phillips #000 screws.
  13. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 13 단계, 이미지 1/1
    • Remove the second silver plate using tweezers or fingers.
결론
christiansvezia
회원 가입일: 10/24/18
1,108 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 350
