주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS 35mm Camera Mode Dial Replacement
필요한 것
  1. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Top Cover: 1 단계, 이미지 1/2 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Top Cover: 1 단계, 이미지 2/2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 3 단계, 이미지 1/1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 4 단계, 이미지 1/3 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 4 단계, 이미지 2/3 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 4 단계, 이미지 3/3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Camera Mode Dial: 5 단계, 이미지 1/1
    • Locate the camera dial (surrounded by a red square) and turn the top cover of the camera upside down for access to the screw underneath the dial.
  6. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 6 단계, 이미지 1/1
    • Using a PH000 screwdriver bit, remove the silver screw circled in the picture, which is 3 mm in length and 1 mm in diameter.
  7. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 7 단계, 이미지 1/1
    • Using tweezers, remove the metal part surrounded by the red square.
  8. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: 8 단계, 이미지 1/1
    • Using your fingers, remove the black dial! (The dial is surrounded by a red square in the picture.)
결론
christiansvezia
회원 가입일: 10/24/18
1,108 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 66
전체 시간: 1,865
