주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS 35mm LCD screen Replacement
필요한 것
  1. Canon EOS Rebel XS 35mm LCD screen Replacement, Top Cover: 1 단계, 이미지 1/2 Canon EOS Rebel XS 35mm LCD screen Replacement, Top Cover: 1 단계, 이미지 2/2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm LCD screen Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm LCD screen Replacement: 3 단계, 이미지 1/1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm LCD screen Replacement: 4 단계, 이미지 1/3 Canon EOS Rebel XS 35mm LCD screen Replacement: 4 단계, 이미지 2/3 Canon EOS Rebel XS 35mm LCD screen Replacement: 4 단계, 이미지 3/3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm LCD screen Replacement, LCD screen: 5 단계, 이미지 1/1
    • Using a PH000 screwdriver bit, remove the tiny silver screw circled in the picture, which is 2 mm in length and 1 mm in diameter.
  6. Canon EOS Rebel XS 35mm LCD screen Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With your fingers or tweezers, remove the brass-colored part.
  7. Canon EOS Rebel XS 35mm LCD screen Replacement: 7 단계, 이미지 1/2 Canon EOS Rebel XS 35mm LCD screen Replacement: 7 단계, 이미지 2/2
    • With your fingers (probably not tweezers or something similar, so you don't damage the screen), remove the LCD screen.
결론
christiansvezia
회원 가입일: 10/24/18
1,108 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 375
