주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS 35mm Lens Mount Parts Replacement
필요한 것
  1. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement, Lens Mount Parts: 1 단계, 이미지 1/1
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 6 mm in length and 1.25 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 2 단계, 이미지 1/1
    • Using a PH000 screwdriver bit, remove the 5 black screws circled in the picture, which are all 5.5 mm in length and 2 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Simply using your fingers - although you can use something else such as tweezers - remove the first layer of the lens mount. This first layer is black, plastic, has a red dot at the top, and so on.
  4. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 4 단계, 이미지 1/1
    • Using (preferably) tweezers - although you can also use your fingers - remove the flimsy brass-colored layer of the lens mount.
  5. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 5 단계, 이미지 1/1
    • Using (preferably) tweezers - although you can also use your fingers - remove the silver layer of the lens mount.
결론
Reassembly can be a lot harder than disassembly for this part of the camera, which accounts for the large range in estimated time.
christiansvezia
회원 가입일: 10/24/18
1,108 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 382
