주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS 35mm Top Cover Replacement
필요한 것
  1. Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: 1 단계, 이미지 1/2 Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: 1 단계, 이미지 2/2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Top Cover Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Top Cover Replacement: 3 단계, 이미지 1/1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Top Cover Replacement: 4 단계, 이미지 1/3 Canon EOS Rebel XS 35mm Top Cover Replacement: 4 단계, 이미지 2/3 Canon EOS Rebel XS 35mm Top Cover Replacement: 4 단계, 이미지 3/3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
christiansvezia
회원 가입일: 10/24/18
1,108 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 293
