주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS Grip Replacement
필요한 것
  1. Canon EOS Rebel XS Grip Replacement, Latch Side Cover: 1 단계, 이미지 1/1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Grip Replacement: 2 단계, 이미지 1/1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Grip Replacement, Disassembling Canon EOS Rebel XS Front Cover: 3 단계, 이미지 1/1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Grip Replacement: 4 단계, 이미지 1/1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Grip Replacement, Grip: 5 단계, 이미지 1/1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Canon EOS Rebel XS Grip Replacement: 6 단계, 이미지 1/1
    • Use your fingertip to pry off the external shutter port cover.
  7. Canon EOS Rebel XS Grip Replacement: 7 단계, 이미지 1/1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Canon EOS Rebel XS Grip Replacement: 8 단계, 이미지 1/3 Canon EOS Rebel XS Grip Replacement: 8 단계, 이미지 2/3 Canon EOS Rebel XS Grip Replacement: 8 단계, 이미지 3/3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Canon EOS Rebel XS Grip Replacement: 9 단계, 이미지 1/1
    • Once the grip is loose, use your fingers to remove it from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Bussone
회원 가입일: 01/28/11
1,251 평판
안내서 11개 작성하였습니다
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 회원
CPSU-REGAN-W11S3G41
2 회원들
안내서 21개 작성하였습니다
댓글 한 개
Little confused. Some pics are from a analog Canon, other from a digital Canon...
Gustavo Aguiar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 24
전체 시간: 3,574
