주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS Interior Eyepiece Replacement
필요한 것
  1. Canon EOS Rebel XS Interior Eyepiece Replacement, Latch Side Cover: 1 단계, 이미지 1/1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Interior Eyepiece Replacement: 2 단계, 이미지 1/1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Interior Eyepiece Replacement, Disassembling Canon EOS Rebel XS Front Cover: 3 단계, 이미지 1/1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Interior Eyepiece Replacement: 4 단계, 이미지 1/1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Interior Eyepiece Replacement, Back Cover: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Canon EOS Rebel XS Interior Eyepiece Replacement: 6 단계, 이미지 1/1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Canon EOS Rebel XS Interior Eyepiece Replacement, Top Panel: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  8. Canon EOS Rebel XS Interior Eyepiece Replacement: 8 단계, 이미지 1/1
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  9. Canon EOS Rebel XS Interior Eyepiece Replacement: 9 단계, 이미지 1/1
    • You can use your fingers to pull the top panel of the camera.
  10. Canon EOS Rebel XS Interior Eyepiece Replacement, Interior Eyepiece: 10 단계, 이미지 1/1
    • After removing the top panel, you can use your fingers to remove the eye piece from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Bussone
회원 가입일: 01/28/11
1,251 평판
안내서 11개 작성하였습니다
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 회원
CPSU-REGAN-W11S3G41
2 회원들
안내서 21개 작성하였습니다
댓글 2개
Is there a part number to order the interior eyepiece? It does me no good to take it apart if I don't have or can't find a replacement for it.
Erik - 답글
How do you replace the internal battery?
rideswchrist - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 7,164
