주요 콘텐츠로 건너뛰기
Canon EOS Rebel XS LCD Replacement
필요한 것
  1. Canon EOS Rebel XS LCD Replacement, Latch Side Cover: 1 단계, 이미지 1/1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS LCD Replacement: 2 단계, 이미지 1/1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS LCD Replacement, Back Cover: 3 단계, 이미지 1/1
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  4. Canon EOS Rebel XS LCD Replacement: 4 단계, 이미지 1/1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  5. Canon EOS Rebel XS LCD Replacement, LCD: 5 단계, 이미지 1/1
    • Use the tweezers to gently remove the straps (in the teal box).
    • Use the Phillips Screwdriver to remove the four screws (in the red dots).
    • Use your fingers to remove the silver plate.
  6. Canon EOS Rebel XS LCD Replacement: 6 단계, 이미지 1/1
    • Use the Spudger on the edges of the screen.
    • Once one end is lose, use the tweezers to lift the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Daniel Bussone
회원 가입일: 01/28/11
1,251 평판
안내서 11개 작성하였습니다
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 회원
CPSU-REGAN-W11S3G41
2 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 7,284
