주요 콘텐츠로 건너뛰기
Canon EOS Rebel XSi Front Panel Replacement
필요한 것
  1. Canon EOS Rebel XSi Front Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Front Panel Replacement: 2 단계, 이미지 1/1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Front Panel Replacement: 3 단계, 이미지 1/1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Front Panel Replacement: 4 단계, 이미지 1/1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Front Panel Replacement: 5 단계, 이미지 1/1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Front Panel Replacement: 6 단계, 이미지 1/1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Front Panel Replacement: 7 단계, 이미지 1/1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Front Panel Replacement: 8 단계, 이미지 1/1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Front Panel Replacement, Front Panel: 9 단계, 이미지 1/1
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  10. Canon EOS Rebel XSi Front Panel Replacement: 10 단계, 이미지 1/1
    • Remove front grip by gently peeling from the edge towards the center of the camera
  11. Canon EOS Rebel XSi Front Panel Replacement: 11 단계, 이미지 1/1
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  12. Canon EOS Rebel XSi Front Panel Replacement: 12 단계, 이미지 1/1
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  13. Canon EOS Rebel XSi Front Panel Replacement: 13 단계, 이미지 1/3 Canon EOS Rebel XSi Front Panel Replacement: 13 단계, 이미지 2/3 Canon EOS Rebel XSi Front Panel Replacement: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
결론
다른 2명이 해당 안내서를 완성하였습니다.
Erik Mork
회원 가입일: 01/27/17
602 평판
안내서 5개 작성하였습니다
Cal Poly, Team 22-10, Maness Winter 2017 Cal Poly, Team 22-10, Maness Winter 2017 회원
CPSU-MANESS-W17S22G10
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 1,236
