주요 콘텐츠로 건너뛰기
Canon ImageCLASS MF4350d Replace Scanner Glass Replacement
필요한 것
  1. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement, Scanner Disassembly: 1 단계, 이미지 1개 중 1개
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 2 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 2 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 3 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 3 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 3 단계, 이미지 3개 중 3개
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 4 단계, 이미지 1개 중 1개
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 5 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: 5 단계, 이미지 2개 중 2개
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
  6. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement, Replace Scanner Glass: 6 단계, 이미지 1개 중 1개
    • Take out the damaged glass and fit the replacement glass to the printer according to the picture.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tanner Papenfuss
회원 가입일: 09/30/13
584 평판
안내서 4개를 작성함
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 회원
CPSU-FORTE-F13S13G1
5 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 60
전체 시간: 9,705
