주요 콘텐츠로 건너뛰기
Canon ImageCLASS MF4350d Transformer Replacement
필요한 것
  1. Canon ImageCLASS MF4350d Transformer Replacement, Front Paneling: 1 단계, 이미지 1개 중 1개
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Transformer Replacement: 2 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Transformer Replacement: 2 단계, 이미지 2개 중 2개
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Transformer Replacement: 3 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Transformer Replacement: 3 단계, 이미지 2개 중 2개
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: 4 단계, 이미지 3개 중 1개 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: 4 단계, 이미지 3개 중 2개 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: 4 단계, 이미지 3개 중 3개
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: 5 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: 5 단계, 이미지 2개 중 2개
    • Locate the yellow wire connected to the metal box.
    • Carefully pull the yellow wire from the black connector.
    • Wires may detach completely from plug so tug very gently.
  6. Canon ImageCLASS MF4350d Transformer Replacement: 6 단계, 이미지 2개 중 1개 Canon ImageCLASS MF4350d Transformer Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the spring.
    • Unhook the spring on the side of the metal box.
  7. Canon ImageCLASS MF4350d Transformer Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the 10mm screw attaching the metal plate to the printer.
  8. Canon ImageCLASS MF4350d Transformer Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the transformer out of the printer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Helena Yanez
회원 가입일: 09/29/13
461 평판
안내서 4개를 작성함
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 회원
CPSU-FORTE-F13S13G1
5 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 3,160
