주요 콘텐츠로 건너뛰기
Canon MF4700n Laser Toner Cartridge Replacement
필요한 것
  1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: 1 단계, 이미지 3개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: 1 단계, 이미지 3개 중 2개 Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: 1 단계, 이미지 3개 중 3개
    • Turn off the printer.
    • Make sure that the energy saver button is not lit up. If it is, the printer needs to be turned off.
  2. Canon MF4700n Laser Toner Cartridge Replacement: 2 단계, 이미지 2개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the operation panel and lift it up to reveal the toner cover.
    • Make sure there is nothing on top of the printer.
    • Potential for Device Damage: Forcing the operation panel to open may cause damage to the printer.
  3. Canon MF4700n Laser Toner Cartridge Replacement: 3 단계, 이미지 3개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement: 3 단계, 이미지 3개 중 2개 Canon MF4700n Laser Toner Cartridge Replacement: 3 단계, 이미지 3개 중 3개
    • Open the toner cover to reveal the toner cartridge.
  4. Canon MF4700n Laser Toner Cartridge Replacement: 4 단계, 이미지 3개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement: 4 단계, 이미지 3개 중 2개 Canon MF4700n Laser Toner Cartridge Replacement: 4 단계, 이미지 3개 중 3개
    • Grab the ledge of the cartridge and pull it out.
  5. Canon MF4700n Laser Toner Cartridge Replacement: 5 단계, 이미지 2개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement: 5 단계, 이미지 2개 중 2개
    • Grab a new/working toner cartridge.
    • If the cartridge is new, then there will be plastic components on it. Follow the manual that comes with the new cartridge to remove the plastic components.
    • Shake the cartridge to distribute the toner evenly inside.
  6. Canon MF4700n Laser Toner Cartridge Replacement: 6 단계, 이미지 3개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement: 6 단계, 이미지 3개 중 2개 Canon MF4700n Laser Toner Cartridge Replacement: 6 단계, 이미지 3개 중 3개
    • On both sides of the cartridge, there are two knobs sticking out.
    • Inside the toner cover, there are two toner guides, one on each side.
    • Align the knobs with the toner guides and push the cartridge securely all the way in.
  7. Canon MF4700n Laser Toner Cartridge Replacement: 7 단계, 이미지 3개 중 1개 Canon MF4700n Laser Toner Cartridge Replacement: 7 단계, 이미지 3개 중 2개 Canon MF4700n Laser Toner Cartridge Replacement: 7 단계, 이미지 3개 중 3개
    • Close the toner cover.
    • Lower the operation panel.
결론
The Canon MF4700n Printer should print normally unless a different component is broken.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Raymond Mach
회원 가입일: 01/16/21
212 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 69
전체 시간: 2,263
