주요 콘텐츠로 건너뛰기
Canon Optura 100MC Speaker Replacement
필요한 것
  1. Canon Optura 100MC Speaker Replacement, The side of the Device: 1 단계, 이미지 1/1
    • Orient the camera so that the viewfinder is on your left and the lens is on your right.
    • Remove the 4mm #00 Phillips screw.
  2. Canon Optura 100MC Speaker Replacement: 2 단계, 이미지 1/1
    • Reorient the camera with the back button pad and viewfinder towards you.
    • Remove the three 4mm #00 Phillips screws shown on the rear face of camcorder.
  3. Canon Optura 100MC Speaker Replacement: 3 단계, 이미지 1/2 Canon Optura 100MC Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the plastic cover from the rear of the camcorder by gently pulling it towards you while holding the camera as shown.
    • The Battery Should be removed at this point, please ignore it in the picture.
  4. Canon Optura 100MC Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the 4mm #00 Phillips screw located to the right of the LCD release switch.
  5. Canon Optura 100MC Speaker Replacement: 5 단계, 이미지 1/1
    • Open the LCD by using the release switch.
    • Reorient the camera with the playback button pad and edge of LCD screen facing you.
    • Remove the 4mm #00 Phillips screw shown.
  6. Canon Optura 100MC Speaker Replacement: 6 단계, 이미지 1/1
    • Reorient the camera with the top facing you. The side with the LCD screen should be on the right and the other side panel should be on the right.
    • Open the pop up flash on the top of the camcorder.
    • A loud clicking noise is expected.
  7. Canon Optura 100MC Speaker Replacement: 7 단계, 이미지 1/2 Canon Optura 100MC Speaker Replacement: 7 단계, 이미지 2/2
    • Reorient the camera with the bottom facing you, LCD screen on the right, side panel on the left.
    • Open the tape deck by sliding the switch and moving the deck cover to the left as shown.
  8. Canon Optura 100MC Speaker Replacement: 8 단계, 이미지 1/1
    • Remove 4mm #00 Phillips screw.
  9. Canon Optura 100MC Speaker Replacement: 9 단계, 이미지 1/1
    • Reorient camera with lens facing you.
    • Remove the #00 Philips 4mm screw shown on the hinge of the tape deck cover.
  10. Canon Optura 100MC Speaker Replacement: 10 단계, 이미지 1/2 Canon Optura 100MC Speaker Replacement: 10 단계, 이미지 2/2
    • To remove the camcorder lens hood, twist the hood to counterclockwise and it will come loose, then pull towards you.
  11. Canon Optura 100MC Speaker Replacement: 11 단계, 이미지 1/2 Canon Optura 100MC Speaker Replacement: 11 단계, 이미지 2/2
    • Close the tape deck by gently pushing it toward the body of the camera.
    • Slide and remove the plastic cover on the bottom right, exposing the interface shown.
  12. Canon Optura 100MC Speaker Replacement: 12 단계, 이미지 1/2 Canon Optura 100MC Speaker Replacement: 12 단계, 이미지 2/2
    • Gently pull the front plastic cover towards you to remove.
  13. Canon Optura 100MC Speaker Replacement: 13 단계, 이미지 1/1
    • Remove 2 Philips #00 4mm screw shown.
  14. Canon Optura 100MC Speaker Replacement: 14 단계, 이미지 1/1
    • Reorient the camera so you are looking at the side of the camera with the viewfinder on the left and lens on the right.
    • Holding the camera as shown,remove the 4mm #00 Phillips screw.
  15. Canon Optura 100MC Speaker Replacement: 15 단계, 이미지 1/1
    • Remove the 4 Philips #00 4mm screws shown.
  16. Canon Optura 100MC Speaker Replacement: 16 단계, 이미지 1/1
    • Reorient the camera with the lens facing you.
    • Gently pull the side panel of the camera to the right to remove.
    • Be aware that that there are wires connecting the cover to the body of the device, so the side cover will not come off entirely.
  17. Canon Optura 100MC Speaker Replacement: 17 단계, 이미지 1/1
    • The side of the device should now be open as shown. Again, there are wire connections between the side cover and the body of the camcorder. Do not separate the two entirely!
  18. Canon Optura 100MC Speaker Replacement, Speaker: 18 단계, 이미지 1/1
    • Remove the screw above the speaker's housing.
  19. Canon Optura 100MC Speaker Replacement: 19 단계, 이미지 1/1
    • Remove the small battery with the "Caution" on it.
  20. Canon Optura 100MC Speaker Replacement: 20 단계, 이미지 1/1
    • Remove the screw from inside the battery housing.
  21. Canon Optura 100MC Speaker Replacement: 21 단계, 이미지 1/1
    • Remove the 3 screws holding the metal piece over the speaker.
  22. Canon Optura 100MC Speaker Replacement: 22 단계, 이미지 1/1
    • Lift up and remove the metal cover.
  23. Canon Optura 100MC Speaker Replacement: 23 단계, 이미지 1/1
    • Lift and remove the speaker.
  24. Canon Optura 100MC Speaker Replacement: 24 단계, 이미지 1/1
    • Replace the broken speaker with a new one.
    • The speaker's wires need to be desoldered.
결론
Jeanette Neethling
회원 가입일: 01/19/11
531 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-12, Amido Winter 2011 Cal Poly, Team 1-12, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G12
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 718
