주요 콘텐츠로 건너뛰기
Canon PIXMA MP620B USB Reader Replacement
필요한 것
  1. Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: 1 단계, 이미지 2개 중 1개 Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: 1 단계, 이미지 2개 중 2개
    • Locate the tabs on the top of the panel that hook down and into the black side panel.
    • Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
    • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
  2. Canon PIXMA MP620B USB Reader Replacement, Loosen the back panel: 2 단계, 이미지 1개 중 1개
    • Remove the two screws from the back right black panel using the Phillips #00 screwdriver.
  3. Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: 3 단계, 이미지 2개 중 1개 Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: 3 단계, 이미지 2개 중 2개
    • There is a tab you will have to push down to remove the part.
    • Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
    • You will hear some snapping. Don't panic: this is just the clips un-clipping.
  4. Canon PIXMA MP620B USB Reader Replacement, Take off the black side panel: 4 단계, 이미지 1개 중 1개
    • After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
  5. Canon PIXMA MP620B USB Reader Replacement, Unscrew 2 screws from USB chip: 5 단계, 이미지 1개 중 1개
    • Remove the two screws from the USB reader using the Phillips #00 screwdriver.
    • The angle for removing the screws can be somewhat challenging, try not to get too frustrated.
  6. Canon PIXMA MP620B USB Reader Replacement, Pull out USB chip and disconnect white wire: 6 단계, 이미지 1개 중 1개
    • Disconnect the large white ribbon cable that leads to the USB reader. As you are pulling out the USB reader, carefully detach the ribbon.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Val Fedorikhin
회원 가입일: 10/12/14
860 평판
안내서 5개를 작성함
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 회원
CPSU-MANESS-F14S6G21
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 9
전체 시간: 897
