주요 콘텐츠로 건너뛰기
Canon PIXMA iP3600 AC Adapter Replacement
  1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: 1 단계, 이미지 2개 중 1개 Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: 1 단계, 이미지 2개 중 2개
    • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
    • Remove power cord by disconnecting it from the AC Adapter.
  2. Canon PIXMA iP3600 AC Adapter Replacement: 2 단계, 이미지 2개 중 1개 Canon PIXMA iP3600 AC Adapter Replacement: 2 단계, 이미지 2개 중 2개
    • Pinch upper and lower prongs, moving them away from the AC adapter.
  3. Canon PIXMA iP3600 AC Adapter Replacement: 3 단계, 이미지 2개 중 1개 Canon PIXMA iP3600 AC Adapter Replacement: 3 단계, 이미지 2개 중 2개
    • The AC adapter will now be loose, and able to come away from the printer.
    • Grasp the AC adapter and pull it toward you to remove it.
  4. Canon PIXMA iP3600 AC Adapter Replacement: 4 단계, 이미지 1개 중 1개
    • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
  5. Canon PIXMA iP3600 AC Adapter Replacement: 5 단계, 이미지 3개 중 1개 Canon PIXMA iP3600 AC Adapter Replacement: 5 단계, 이미지 3개 중 2개 Canon PIXMA iP3600 AC Adapter Replacement: 5 단계, 이미지 3개 중 3개
    • Grasp the white connector head that is attached to the end of the blue cord.
    • Disconnect the white connector head by gently pulling it away from the AC adapter.
    • You have successfully removed the AC adapter.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Caitlyn
회원 가입일: 10/07/14
1,202 평판
안내서 4개를 작성함
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G3
3 회원들
안내서 8개를 작성함
댓글 3개
Does anybody know the pin-out for these power supplies?
James Rudee - 답글
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - 답글
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 25
전체 시간: 5,070
