주요 콘텐츠로 건너뛰기
Canon PIXMA iP3600 Ink Cartridges Replacement
  1. Canon PIXMA iP3600 Ink Cartridges  Replacement, Ink Cartridges: 1 단계, 이미지 1개 중 1개
    • Press the power button to turn on the printer.
  2. Canon PIXMA iP3600 Ink Cartridges  Replacement: 2 단계, 이미지 1개 중 1개
    • Pull down the front output tray cover.
  3. Canon PIXMA iP3600 Ink Cartridges  Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the printer lid.
  4. Canon PIXMA iP3600 Ink Cartridges  Replacement: 4 단계, 이미지 1개 중 1개
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Canon PIXMA iP3600 Ink Cartridges  Replacement: 5 단계, 이미지 2개 중 1개 Canon PIXMA iP3600 Ink Cartridges  Replacement: 5 단계, 이미지 2개 중 2개
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Caitlyn
회원 가입일: 10/07/14
1,220 평판
안내서 4개를 작성함
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G3
3 회원들
안내서 8개를 작성함
1가이드 댓글
Hi, all the years I've been using original ink but it became so expensive and my cuz gave me generic ones. I've installed it last night but then noticed that my images totally not the same on my writeable dvd's,eg. brown colour images (faces) or yellowish.
Is it because of the generic ink cartridges or is there a problem with the printer.
Please help me urgently?
You can even email me directly msmidt@distell.co.za
Marlin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 5,048
